Heating and Hot water
Originally Posted By: rbennett
Need some help
Just inspected a home today that look like the H2o heater was suppling hot water to an air box that contained a set of coils for heat and cooling.
Is this a legal way to heat a house by using the hot water heater??
rlb
Originally Posted By: apolillo
I see this a lot in condos. There should be a mixing valve to make sure the water temp is reduced for all faucets. They are a strange beast.
Anatol
Originally Posted By: wmartin
Richard,
I beleive that the heating and cooling system were helping the h2o heater supply hot water. This type of system was popular in the sunshine states in the 80's. Concept was to take the heat from the cooling unit and heat the water.
Bill
Bill
Understand what you are saying but this was not how this one was hooked up
I looked a little home ownerish or a contractor that was trying a new way of saving money
Trying to get some more info before I write it up
rlb
Originally Posted By: rcooke
Have a look here this might be what you are talking about .
Combination Furnace /water heater
Roy sr
http://www.energystar.gov/ia/partners/bldrs_lenders_raters/downloads/BuilderGuide3B.pdf
Originally Posted By: dvalley
David Valley
MAB Member
http://www.masscertified.com
Dave and all that put the other thread togeather thank you
That is how they are heating the whole house. Now I can write that part of the report.
Main issues -- water heater has a lot of rust flakes in burner chamber -- workmanship on pipes was poor.
Thanks again
rlb
