Hi all, I’m new to this forum. I’ve passed the Ethics course, the SOP course, and the Safe Practices course. I’m moving on to the 25 Standards Every Inspector Should Know course. I’m curious which courses you all have done and what you found most valuable in your studying process. Thanks!
My opinion is that you should do all of the courses that pertain to what you could come across while inspecting.
I sub out radon testing, but I’m glad I took the courses offered on the subject. Radon is very prevalent in Iowa. I do not present myself as an expert on the subject, but I should know enough to explain why they set the monitor where they did or explain how a mitigation system works.
If you are in an area where septic systems are common, it would be a good idea to take the course on them, so you have a basic knowledge of how they work. Even though you exclude them from your inspection.
Exactly what Jeff said!
Most valuable has been two fifths of JD and a case of Coke!
Hi SB. Pleasure to meet you.
Keep notes on every subject. I used Word.
Use sticky note as well for hard copy books.
Refresh courses the night prior to taking your examination.
Good luck.
Thank you all for the advice and encouragement! I look forward to learning a lot!
Coke is bad for you. Stick with the JD!
