I need some help identifying this waste pipe material. My gut says Transite but its also giving me ABS vibes. Any help would be greatly appreaciated.
How old is the house?
Since the OP is in NJ, there is the possibility of it being Orangeburg piping, (New York based), depending on the age.
ABS is last on my list.
My wag is concrete or steel.
From Google AI. Rust in transit pipes, appearing as red, brown, or reddish-brown streaks or discoloration on the pipe’s surface. Transite (asbestos-cement) pipes join together using rubber gasketed couplings like in your image.
Can you post the video? That would be a lot more helpful than those two photos
Good info here
Built in 1960. The cleanout was cast iron where it went into the ground and then it transitioned to this.
Yes I tried AI too, came back with ame thing.
It looks more like galvanized pipe. Transite pipe material doesn’t rust. Unless those are just rust spots/deposits from the cast iron pipe.
The rust is from the cast iron upstream.
It may well be transite. Though I’ve never experienced transite used for sewer line pipe in my area. Everything else, cast iron, clay, orangeburg, and of course PVC and ABS.
I agree with @jjonas and think it’s orangeburg too, it could be an optical illusion, but the pipe looks oval, which is a sign of orangeburg.
That’s also what I thought at first looking at the video. But that would be too easy.
I run across this in certain cities in WA…Appears to be a typical larger utility portion (Under sidewalk and street) transite with a rubber gasket conenction between segments.
Attached is an image from yesterday - 8” transite at a hub tie in.
John, I think you are on the right tract.
Just trying to help.
Good post, Brian.
How to you post and image with a link. Copy paste and embed a link in the image.
Never understood that.
Thanks in advance.
