Gas fired 150,000 Btuh with Belt-Drive motor so we know its pre-1980
Thoughts on age of unit.
Mdl: 21LG-30J2 / S/N: 24-303-022
The upflow gas fired forced air furnace located in the basement was operated from it thermostat thru a normal cycle. The furnace should be considered as end of life budget for replacement :p:D
House was built in late 50’s … I’m guessing Unit is Original OR close.
Prolly not quite that old Ida guessed mid 60’s
If that furnace was a tree it would be 50 feet tall. Probably last forever too, seein as it lasted this long. New furnace will use less fuel.
