Reposted from OLD FORUM-
I have received a few e-mails from HI’s wanting to know a good resource to explain when the GFCI was introduced and how it has evolved.
I came across this neat PDF and figured I would share it with you to help HI’s explain to clients how the GFCI has evolved in regards to safety issues and so on to clients that lets say do not have a GFCI in their bathroom or kitchen counters and so on.
…or I find this one easier to read (I need it that way)…
DATES **GFCI **REQUIRMENTS WERE ESTABLISHED:
1971 Receptacles within 15 feet of pool walls
1971 All equipment used with storable swimming pools
1973 All outdoor receptacles
1974 Construction Sites
1975 Bathrooms, 120-volt pool lights, and fountain equipment
1978 Garages, spas, and hydro-massage tubs
1978 Outdoor receptacles above 6feet 6inches grade access exempted
1984 Replacement of non-grounding receptacles with no grounding conductor allowed
1984 Pool cover motors
1984 Distance of GFCI protection extended to 20 feet from pool walls
1987 Unfinished basements
1987 Kitchen countertop receptacles within 6 feet of sink
1987 Boathouses
1990 Crawlspaces (with exception for sump pumps or other dedicated equip.)
1993 Wet bar countertops within 6 feet of sink
1993 Any receptacle replaced in an area presently requiring GFCI
1996 All kitchen counters – not just those within 6 feet of sink
1996 All exterior receptacles except dedicated de-icing tape receptacle
1996 Unfinished accessory buildings at or below grade
1999 Exemption for dedicated equipment in crawlspace removed
