[ASKNACHI]This question was posted on AskNACHI.org by George Johnson (from Gary, Indiana). [/ASKNACHI]A 60 amp electrical service panel at a 2,800 square foot home would be: a. undersized; b. oversized; c. the right size
In the bathroom, a good location for a permanently installed ceiling heat lamp is: a. over an empty space so as not to overheat anything; b. over the path of the bathroom door; c. over the toilet seat to keep warm
Isolated links on light fixture pull chains prevent: a. the user from being shocked or b. overheating of the fixture
Fuses do NOT provide protection against: a. short circuits; b. lightning surges; or c. large ground faults
When a well pump comes on and off quickly, this is a:
a. short cycle; b. an intermediate cycle; or c. a long cycle
Exterior plumbing stack vents should be at least 3 feet above operable doors and windows. True or False
When inspecting a boiler, always test the air bleed valves on the radiators. True or False
The purpose of spacing between the exterior deck floorboards is to allow rainwater to pass through. True or False ; or Other reason
