maybe. You can use keywords at each comment and then as you scroll look for the keywords. Or, you can select the option under menu that only shows the keywords. Lastly, you can make more sub folders at the Template ALL Comments window in the main version and then you can use the auto-comment “filter” drop down that will show up in the HG Companion to get to that specific sub folder.
For instance your plumbing folder may have waste and supply and all the comments associated with these two. You could go to Template ALL COMMENTS and make sub folders under supply like sinks, toilets, hose bibs, piping, etc. and then your comments can be quickly filtered
