Homeowner Central Air maintenance
A homeowner can do himself a “world of good” which will result in some long term cost savings for his central air-conditioning system. Any homeowner can perform periodic inspections and maintenance to their homes central air-conditioning system.
At season’s end, simply: Clean the exterior condenser unit and components as removing leaves, cleaning debris and adding lub oil to the motor if needed. Also, clean the condensate drain line as well as air filter. Cover the unit during winter. Close the air-air-distribution registers.
These are some of the helpful hints for a reliably cool summer next season.
