Inspected this house and the exterior siding was very wavy, but had a good paint finish on it. Looked a little deeper and noticed there are no metal transition strips at the seams/butted edge.
The entire home is missing the transition strips. The seams have been filled with a large amount of caulking which is now starting to crack.
My questions are:
Can the siding be installed with out the transition clips? I would think not
Going to recommend a siding contractor to my client for further evaluation. Any other input from you guys would be helpful.
The home is in a gated community with 3 types of exteriors (horzt1-11 type siding, lap board & stucco)
The other homes with the horz siding do have transition clips.
I suspect that all that could go wrong with the installation of this product, did due to disregard to proper manufactures installation guidelines and standard pracice of building.
My guess is that the siding was installed to tight which doesn’t allow for expansion and contraction. The wavyness is usually due to the material expanding.
