Hot Wire… ouch.
John does it look familiar I took your image and thermally tune it to make it appear even hotter:D </IMG>
Changed the palette and adjusted the span some more, Your image indicated 150 degrees with your setting on your camera in the hottest section of the right wire. I changed your E valve and the T reflected adjusted the span and got a 15 degree temp rise just playing around with it.
BTW for those that had not thought of it would be wise if using an infrared image in a legal document to make it PDF so one with FLIR software can not change your image as I did to Johns
