The two stories house is located in Manassas VA. It have a “floating wood foundation” with visible end joists and the rim joists are not installed. Please let me know what recommendation should you suggest.
Never seen it in person. There is a post about this on the board. From what I remember the only thing that can be done now is keep the ends protected by paint or similar and keep water away. I’ll try to find the post in a bit.
Hi Simon,
Thank you so much for your prompt answer, I’ll take in consideration your commentary.
CARLOS PINILLOS
DPOR LICENSED HOME INSPECTOR
Home Inspector since 2005
Housing Inspection Foundation
InterNachi
General Liability Insured
General Contractor
Designer
571.221.0987
Carlos, if you want this to be on every post that you make without typing it over and over, do this:
SIGNATURE: Click on your face in the upper right hand corner of this page. Then click on your name to the left of the bell. Then click on preferences. Then click on profile and scroll down to signature and fill out the information that you want to appear under every post that you make. AND LAST, scroll to the bottom of the page and click SAVE CHANGES.
Thank you Larry!
CARLOS PINILLOS
InterNachi
General Contractor
Designer
571.221.0987
Pleasure…
