What could be causing the rot beneath the windows? And is the gap between the window casing and the side of the house due to latent problems or just normal wear on the surface with the caulk strip getting firm over time.
Bad enough!
Moisture intrusion!
That’s all you get as long as you HIDE Who and What you are from us!!!
Yes, and the process will be accelerated now that you have picked at the wound and caused further damage.
Fair enough. I am not a home inspector, but I am interested in the profession. I work a regular 9-5 job and do a lot of DIY stuff.
If a home inspector the buyer hired picked at the wound than I would be deeply troubled LOL. I am the homeowner so I picked at it to see how bad it is in preparation for either a DIY repair or hiring a professional carpenter.
Probably a good idea. That scenario has a good chance of uncovering significant further damage once repairs are in progress.
Most, or at least a lot, of the water causing the damage is coming in where the caulking has failed at the window trim. Causing the damage to the wood below. Apply a quality waterproof caulk around the outside of the window trim. And the wood, at least what you’re showing, should be salvageable.
Only after ALL the old caulk is prepped/REMOVED prior to installing new caulk/sealant!
Something tells me that process will reveal further damage.
It’s time you remove that rotted trim and also replace those windows and apply proper flashing around the window. If you don’t know how, hire a professional.
