Originally Posted By: hgordon This post was automatically imported from our archived forum.
This is an outlet box at the front of a house I just did. They added about 24" of height to the planter area out front and now this recepticle box is begining to be covered!
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Yes, needs to be “above” ground, and that is not. The end of the lowest fitting going into that box also needs to be “above” ground.
While there is no specified 'height', if I can't slide my fingers under it, it is too close.
Just as importantly, if this is located IN a planter and below the top overflow water level, then it needs to be direct burial and underwater rated, and that includes the holes into the wall behind it. Same applies if in a recessed area (such as if they raised the planting area 24" all around the receptacle, then left a depression so the receptacle would still be 'above ground'. Water will likely collect around it, flooding over it.
