More than one-third of Americans use fireplaces, wood stoves, and other fuel-fired appliances as primary heat sources in their homes. Unfortunately, many people are unaware of the fire risks when heating with wood and solid fuels.
Heating fires account for 36% of residential home fires in rural areas every year. These fires are often due to creosote buildup in chimneys and stovepipes. All home heating systems require regular maintenance to function safely and efficiently.
InterNACHI® encourages homeowners to practice the following fire safety steps to keep those home fires safely burning. Remember, fire safety is a personal responsibility.
I did a quick search online that said it’s more like 1.3% use wood and as much as 12% use some other form of fireplace or stove for secondary heating. I don’t know if it was just old information or a typo. I could believe 1/3rd of homes have chimneys, pellet stoves, etc. Just not that they use it as a primary source of heat where they have to get up in the middle of the night a couple of times to add fuel to the fire.
I volunteered with the local fire department. Not a whole lot, but enough to hear that modern homes take 4 minutes to burn. Less when they have an open floor plan. And the firemen liked to describe how if the homeowners had a lot of paints and chemicals stored they got too toxic to try to put out. All they could do was try to stop other houses nearby from burning. It’s an insane situation, isn’t it? Be safe out there!
This likely encompasses gas and oil. I don’t ever consider a wood or pellet stove a primary heat source. Any more effort than turning on a thermostat (and paying the bill, I suppose) and it’s not a heat source IMO.
Over the years the only times I’ve found wood/pellet as an attempt at a primary heat source have been in things like mountain cabins that are likely cash buyers (getting financing with no heat source is not easy).
I must’ve clicked on something to make it a “Classified Ad” but it wasn’t on purpose. Oh! I wanted it under the “Class” subject header! It must have cut off the title? Ugh. I’m still learning.
Thinking within the context of the statistic, I believe what they are referring to are people who use some sort of supplemental heating source as their primary heating source.
If other fuel-fired appliances includes gas and oil fired furnaces, IMO the number is too low, but if it’s solid fuel such as wood or pellets, then I think that the number is too high.
I’ve been inspecting properties for almost 23 years and have only seen 3 that I can remember that used wood or pellets as the primary fuel to heat the house here in SW Ohio.
Had a pellet stove insert up in Basement Land. A three story (split level) with the stove insert in the fireplace on the first level (all family room area). It would burn two bags of pellets a day (Wife temperature setting) and heat the whole home (2200 Sq. Ft. conditioned). It was very easy to run and maintain.
That was also in my younger days and we had a pull out couch in the family room. Got a lot of snuggle time in with it.
Saved a lot of money on gas heat. However it was real good exercise loading, unloading, and storing two pallets of pellets at a time.
I sure hope that isn’t what the class actually says. Because it is incorrect, misleading, and very confusing.
I am very confident more than one third of Americans use either wood or other type of fuel fired Appliance has a primary heat source. I would say closer to 75%
Also wood is considered a solid fuel appliance, which is somewhat different than fuel-fired, at least description wise.
Years ago I inspected a house that the sole source of heat was a wooden stove located in the basement. It had an open grate above it that was in the kitchen area. At the time of the inspection, the HVAC system had been installed and upgraded to a heat pump.
The only thing I could note was the open grate on the kitchen floor could be a safety hazard if the downstairs wood stove was in use..
The real question to solve the riddle is how many houses are heated with electricity. All others would be solid fuel. Well, I suppose there are houses without any heat. Hawaii has lots of those. Is a heat source required in Florida, Texas, etc.?
Google/AI says electricity is about 41% electric. So if that class says 35% solid fuel, we’re missing a chunk of houses.
gemini says it’s false on the first part about the percentage but not on the part about people not knowing how dangerous it is. it says the percentage is off by a factor of 30, pretty damned wrong in other words.
“Part 1: “More than one-third of Americans use fireplaces, wood stoves, and other fuel-fired appliances as primary heat sources.”
Verdict: Statistically False.
Research into U.S. housing and energy data shows that while many Americans use these appliances for ambiance or supplemental heat, they are rarely the primary source of heat.
Primary Wood Heating: According to the U.S. Census Bureau’s American Community Survey (ACS) and the EIA’s Residential Energy Consumption Survey (RECS), only about 1.3% to 1.5% of U.S. households (roughly 1.7 to 2 million homes) use wood as their primary heating fuel.
All “Fuel-Fired” Primary Heat: If “fuel-fired” is expanded to include natural gas, propane, and fuel oil, the number actually rises to over 60%. However, the context of your statement (mentioning fireplaces and wood stoves) implies “solid fuels.”
The Origin of the “One-Third” Statistic: This specific phrasing is frequently found in older safety brochures from FEMA and the U.S. Fire Administration (USFA). However, the official language used by those agencies usually says: “One-third of Americans use fireplaces, wood stoves and other fuel-fired appliances as supplemental heat sources.”
By changing “supplemental” to “primary,” the statement becomes statistically incorrect.
Even counting supplemental use, the number of homes burning wood or pellets is closer to 10–12% (roughly 12.5 million homes), not one-third.
Part 2: “Many people are unaware of the fire risks when heating with wood and solid fuels.”
Verdict: Confirmed (Supported by Fire Incident Data).
While “awareness” is difficult to measure through a survey, fire incident data from the NFPA and USFA suggests that a lack of proper maintenance and safety knowledge is a leading cause of property damage and death.
Heating as a Leading Risk: Heating equipment is the second leading cause of U.S. home fires (behind cooking) and the second leading cause of home fire deaths.
The “Failure to Clean” Factor: Research shows that failure to clean (specifically chimney creosote buildup) is the leading factor contributing to home heating fires, accounting for roughly 25% of all heating fires. This supports the claim that many users are unaware of—or ignore—the necessary maintenance required for solid fuel appliances.
Proximity Issues: A significant number of wood-stove fires are caused by “combustibles too close to the heat source.” This indicates a lack of awareness regarding “clearance to combustibles” (the “3-foot rule” promoted by fire marshals).
Deep Research Data Points (US Only)
To provide more context, here are the most recent relevant figures:
Category
Statistic (Approx.)
Source
Primary Wood/Pellet Users
1.7 million households (1.3%)
US Census ACS
Supplemental Wood Users
8.9 million households
EIA RECS
Total Annual Heating Fires
44,210 per year
NFPA (2016-2020 average)
Leading Cause of Heating Fires
Creosote/Chimney buildup
US Fire Administration
Peak Fire Months
December, January, February
NFPA
Summary Analysis
The statement appears to be a misquoted safety warning.
The “One-Third” Error: The user who wrote this likely swapped the word “supplemental” for “primary.” In the U.S., natural gas and electricity are the dominant primary heating sources.
The Safety Intent: The warning regarding awareness is valid. Fire departments across the U.S. report that a large percentage of wood-fuel fires are preventable, caused by improper ash disposal, lack of chimney sweeping, or placing furniture too close to the stove—all of which stem from a lack of safety awareness.
Final Verdict: The statement is misleading. While the fire risks are very real and often underestimated, the claim that 1 in 3 Americans use these as their main heat source is off by a factor of nearly 30.”
