How would you, what would you propose to fix,repair,stop these kinds of problems…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing36#5451204553850232530
http://picasaweb.google.com/101049034584960315932/Crawlspace#5540665133328086770
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing46#5480527174029286818
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing41#5468581476267439570
Eh umm, those photos of deteriorated blocks, inside and outside, there are quite a few homeowners who have that shtt and one reason why the inside system terds will COVER,HIDE at least PART of the bottom of the basement wall(s), yep. They don’t want anyone, the homeowners, the NEXT HOMEOWNER, a home inspector, city inspector etc to SEE the deterioration they covered up, they didn’t correctly identify and didn’t fix, got that?
Efflorescence…this guy ‘gets-it’, OBVIOUSLY many others do NOT!
http://aggregateresearch.com/forum/viewmessage.aspx?AreaID=820&MID=2360
in part says, “The best way to prevent the problem is to prevent water from infiltrating the blocks…Whenever we see this problem, there is usually a leak somewhere that ALLOWS water to ENTER the block wall…”
Find it, find the problem(s), then fix the problem then clean the dumb efflorescence.
Can’t do that by misguiding,misinforming people and telling them INCOMPETENT DOGSHTT like, Oh 80%-99% of all peoples problems/leaks are due to the GRADE…nonsense.
