How high above a floor in a garage is an appliance with an ignition source required to be located?
SECTION M1307.3 IRC, appliances with an ignition source installed in garages must be located at least 18 inches (457mm) above the floor to prevent igniting heavy flammable vapors.
Exception:
water heater flame arrestor - Google Search
AI Overview**
A water heater flame arrestor is a crucial safety screen located at the bottom of modern gas water heaters. It allows necessary combustion air to enter the burner chamber but blocks external flames, preventing explosive vapors in the surrounding room from igniting.
Also check the manufacturer installations instructions (per 1307.1 and 2005.1 if you want/need a code reference).
