Ahhhh. . .
This would explain why the meter wasn't turning on an inspection I did in the desert this summer.
Two A/C units and a swamp cooler were cooling the house and garage. When I did the panel inspection, the meter was still. I assumed something was wrong and recommended eval by the Utility Co. as the meter is their responsibility.
Wow, I wonder how that turned out
Joe,
Our inspections are limited. We can't typically see behind the meter. How else might we notice this condition if (for instance) the home is unoccupied having almost no load?
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: Joe Tedesco This post was automatically imported from our archived forum.
If the building is supplied with electricity, you could look for a a receptacle outlet so that you could plug in a load which can be any type of equipment. A small electric heater may be best because it may pull more amperage than a lamped pig tail.
If the meter doesn't spin there's a problem!
Calling the utility company is the best bet. I'd suggest asking them for there "Rule Book" so that you can read the part that deals with the subject of this thread.
If the seal has been tampered with, that too could be a sign that something fishy is going on!
If there was a squirrell who found its way through an open knockout and was behind the meter, that has been know to cause outages:
Originally Posted By: dfrend This post was automatically imported from our archived forum.
When working in DC, I have seen some theft of electricity the GHETTO way. You name it : Extension cords from vacant buildings, wires actually tied into the service lines with extension cords run throughout. You think the power company would notice the orange extension cords running back and forth accross the alleys.
