Originally Posted By: pbolliger This post was automatically imported from our archived forum.
Pic Roof 7a
Improperly installed Drain Vent boot on roof (location). Nailed directly on to shingles creating entry points for water and stressing boot.
Recommend evaluation by Lic, qualified roofing contractor.
Originally Posted By: aatkinson This post was automatically imported from our archived forum.
phinsperger wrote:
A narrative is a brief statement within your report. Some narratives may simply inform the client about a particular feature or material without indicating any type of concern and are for the most part benign. The narratives that deal with defects however, are the ones that can either put you in or keep you out of court , depending on how it is written.
Every defect found and written up in a report should contain the following elements. The order is not important as long as the narrative has all the elements. The color is for illustration purposes for this post. The text in an actual report would be all one color.
1) Identify the Component 2) Describe the function of the component 3) Describe the defect 4) How the defect will impact the client 5) How the defect should be corrected (note: this is different from speculating on solutions) 6) Who should correct the defect 7) When the defect should be corrected (amount of urgency)
Example An electricalwire in the main panelis reduced in effective diameter by being nicked. This may cause the nicked area to increase in temperature which is a possible fire hazard. Have the wire replacedby a licensed electricianbefore loading the circuit.
Example
The electricalpanelis outdated and improperly installed. It may not provide adequately protection from electrical fires or shock.Have the panel replacedby a licensed electricianbefore energizing the panel.
Example
A supportingwood beamis not sufficiently supported. This will reduce the load bearing capacity of the beam.Have the bearing for beam evaluatedby a structural engineerbefore putting any weight on the floor.
To use Stuart's wording Weather protectingroof shinglesare damaged in the valley area. This area will be prone to leaks.Have the shingles repaired or replacedby a qualified roofing contractorbefore the next rain.
As with any reporting style it would be advisable to discuss this with legal council before incorporating it into reports.
I bet you had fun typing this post ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
pic roof 8A
Damaged lead drain waste vent flashing. (location) . The flashing is damaged at the top of pipe. Open area will allow water to enter between flashing and pipe down into roofing members. Water intrusion into roofing members will aid in premature end of roof lifespan.
Recommend Lic, qualified roofing contractor to evaluate further.
pic Roof 10a
Roofing system (location) is non-standard method of application. Roof covering appears to have been installed over existing covering and flashed improperly. Recommend evaluation by Lic, qualified roofing contractor.
Pic Roof 11a
Improperly installed flashing and roofing components. Non-standard roofing methods. (location) Water , snow intrusion points at numerous locations will lead to premature end of roofing system.
Chimney improperly flashed, No cap, no cover, no liner observed from (ladder at eaves, binoculars at ground) Recommend complete roofing system evaluation by lic, qualified roofing contractor.
Pic Roof 12 A
Mechanical damage on Shingle roof (location). Shingle has a abrasion damage with gouge and missing granules. Mechanical damage will lead to premature end of life to roofing shingles. Recommend replacement of shingle by qualified lic, roofing contractor.
Originally Posted By: phinsperger This post was automatically imported from our archived forum.
[quote="aatkinson]
I bet you had fun typing this post ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)[/quote]
Yes, but apparently the message has not gotten through to some. Good luck in court ![nachi_sarcasm.gif](upload://6HQh6KbNiD73gqTNQInjrR2zeJw.gif)
Pic 13 a
Sever wear , curling and degradation of roofing shingles at (location). Roofing material at end of useful lifespan . Recommend complete roofing system evaluation by licensed qualified roofing contractor.
Pic 14a
Venting hood on roof at (location) is improperly flashed / sealed to roof decking. This vent maybe installed incorrectly but no determination can be made since amounts of sealant and application methods are beyond normal methods. Recommend evaluation of this installation by qualified licensed roofing contractor.
Pic 15a
Asphalt shingles at (location) on roof are damaged. Shingle tabs have chipped edges possibly from mechanical or weather damage. Damage to shingles reduces the overall lifespan of the roof covering system. Recommend replacing damaged shingles to maintain the lifespan of the overall roof covering system by Lic. qualified roofing contractor.
Pic 16a
Severely damaged shingle on roof at (location) . Water intrusion at this point is very likely and could very possibly damage roof decking below. Recommend replacement of this shingle to maintain life span of roof covering system by Lic, qualified roofing contractor.
Pic 17a
Flashing at chimney roof junction (location) is damaged, missing and modified by non-standard roof flashing methods. Water intrusion is very likely at this point to roofing decking and could lead to considerable costly damage to home . Recommend repair of this ASAP by Lic. qualified roofing contractor.
Pic 18a
Improper roof shingle installation visible on roof at rake edge (location). Shingles are installed in a non-standard method that creates a single continuos channel from apex of roof to eaves. Water shedding design method is not present with this installation method. Possible water intrusion under adjacent shingles and to roof decking. Flashing at rake edge is **** Recommend evaluation and repair by Lic. qualified roofing contractor.
**** Can not see the flashing from this perspective. Cannot complete comment.
Pic 19a
Numerous trees and limbs in contact or in very close proximity to roof at (location). Physical damage to roof will occur by branch / limb movement making contact with roof system. Debris from trees can accumulated on shingles and promote algae growth, fill the gutter system and reduce lifespan of roof system. Recommend trimming branches and limbs in contact and over the roof by professional Arborist. Monitor for further problems and maintain clearance as necessary.
and Roof pic 20a.
Utility company cables (type) are visible in contact with surface of roof at (location) . Mechanical damage to roofing shingles will take place at contact point with movement reducing roof lifespan . Recommend having cable clearance increased or rerouted by *** utility company.
***** unknown cable type, cannot name correct utility company name.
