I am learning about HVAC Systems and attempting to wrap my head around this system. I am sure it is easy, but I am really new at this and need some help. I have labeled the first picture, and I believe the second picture is the Air Handler, but I am not sure. I am just curious on exactly what I am looking at. TIA
Yup your right.
#1 is a side flow furnace. Evap A/C coil has the big black pipe going to it with a PVC drain.
#2 is an up flow something or other. Heat Pump likely. Electric aux heat at the top.
Thank you, Sir! I see you are a fellow Tennesseean! Chattanooga here!
Thank you, Sir
