Hello,
I was able to upload the Picture files for HD format now which is great thanks for your help…
The attached condenser compressor seems at first glance to be fine, upon closer inspection there are 3 concerns.
- The dryer vent is in close proximity which could contribute to excessive dust and lint accumulating in the coil fins.
- The deck has a confined exit and walk way directly next to the compressor which could cause unintentional damage to the unit or injury to individuals especially children.
- The down spout is connected below grade with the visible end of flexible black (perforated) slotted polyethylene drain running at an angle indicating it is near or possibly below the unit pad which may cause uneven settlement over time.
