I found this on an inspection yesterday, No idea what it is... Soffit port?
Check out the attached pic.
It appears to be a 1.25"-1.5" port on the soffit of the garage. Only 1 on the entire perimeter of the home. No idea what I’m looking at. Doesn’t appear to have any screening or bird/pest management noted.
Home is 2001 build, with spray foam insulation on the underside of the roof decking everywhere. (Not sure if that matters but figured perhaps access to spray. My other thought was perhaps an inspection port for roof to wall connections.
Looks like a drain. Maybe a secondary condensate drain? Was it over a window or walkway? 1½ is big for a condensate drain. Maybe drain for an attic water heater auxiliary pan? Do you have any pictures further back? Were you able to trace any/all attic drain lines from equipment to rule that out?
Indirect drainage receptor?
Was there a furnace or air handler in the attic? I agree with others that it looks like a drain.
Negative, Two 4 ton HVAC in the garage, No furnaces, 50 Gal. Electric Tank W/H. Attic was bare.
This is the garage utility wall.
After further review of the photos, the central vacuum system has an “Exclusive self cleaning filter”
So perhaps the exhaust port for the central vacuum, since you can see twin 1.5" PVC tubes going into the attic space. That port is on the soffit approx. 2 feet east of the garage exterior door. So it all seems to line up.
That’s easy to find out.
Energize the vacuum and see if there is pressure or suction at the port.
I would agree. Looks like you answered your own question. :smile:
Yep, there it is.
Isn’t that a song??
Missing the Whoomp.
