system
(system)
Originally Posted By: pdacey
when I opened the SE panel and found this
Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_6310.JPG ]
then found this in the crawl space
Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_6315.JPG ]
Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_6314.JPG ]
and then found this on the interior sub panel
Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_6323.JPG ]
I don't know, do you think they should have a sparky come check it out?
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
system
(system)
2
Originally Posted By: bkelly2
If you are lucky you might get the original installer to come back.
system
(system)
3
Originally Posted By: kfulton
But… you got to smile when it is so obviously apparent. It is easy to explain and correct. Deep inside a voice says, “Gotcha, you cheating bas*%
@ard!”
Who says we don't remove panels? Great example Patrick!
Kelley Fulton
True North Home Inspections
...things you think about in dark spaces...
