What the hell is this? An O trap?
Just wow, what the heck!
I figured if anyone had an answer it would be you Martin!
Simply an S-trap.
Correct JJ. But you can’t deny that’s not an “O”…
Sure I can! How long you been coming to this MB? LOL!
(Note your ‘double negative’).
its just an s trap. it does not matter what direction you turn the pipes and what shape it makes.
is just simply a twisted s-trap with an added elbow at the end. as a s-trap will usually drain straight down.
and also may be leaking by the look at the pipes.
