I need help identifying plumbing in garage
Hello. What do you call this opening where the tube on the wall goes?
The copper tubing is penetrating the wall. :grinning:
Penetration trough walls…Applies to everything from plumbing, electrical, HVAC etc…
A hole? :thinking:
ah that would be Your basic hole in the wall …what You have pictured there are multiple holes in the wall with pipes in them…
Keep it simple Kevin… :joy:
Thank you and apologize for such a newbie question. I thought there is a particular term where a tube goes on a hole. Thank you again.
No problems with “newbie” questions Marc. “Penetrates” is how I describe and the term I use in my reports!
No problem Marc, better to ask than not.
Could it be you’re thinking of conduit or a protective sleeve?
Pipe penetration hole would work, too, Marc.
Larry, you’re getting graphic and the forum police will be here soon to criticize and threaten to leave… :wink:
The rings that cover those holes is called an escutcheon
Promise, Thomas? :innocent: :crazy_face:
Like Brian said above, it’s a pipe penetration and missing the trim called the escutcheon.
Welcome to our forum, Bobby!..Enjoy! :smile:
What is that? Did you mean annular space?
