I have a lot of money on this election, so I’m wide awake and on the edge of my chair.
The fate of our nation is riding on this election. I hope and pray we win.
PA called for trump. That’s 270 once Alaska wakes up. Thanks PA. I can go to sleep now.
Glad it went good for you. MN has zero laws on voter ID.
FYI if you check out a book at a library in MN you need to show your ID, but to cast a vote you don’t.(its just strange) … MN there is no ID/ picture nothing. you just need to tell them your address, and then make your mark on the signature line.
That’s because you are already registered. But to get registered, you will need an ID.
That’s why DemonRats love dead people… they’re already registered! Just give them a name until it matches!!
When I voted yesterday, they didn’t even ask for an address, just my last name.
I always TRY to hand them my ID, (which they usually at least ‘glance’ at). Yesterday the old bitty just waved it away… then proceeded to ask me three times how to spell my last name, (even after I spelled it once for her). After the third time, I stated “That’s why I tried to hand you my ID! My name is simple and common, but people always want to drop the ‘A’ and insert an ‘E’.”
WAFI !!!
In GA, I showed my ID three times at three different stations before I was sent to an electronic voting machine.
I think they should copy my ID directly onto my paper ballot! ![]()
Then the Dems will have your full ID info for next time…
for when your ballot gets lost/misdirected…
then they can easily fill in your votes for you!!
Your in TN! You expect anything else?
I showed up in a wheelchair. They came outside to get me 2 min after I arrived and stayed with me till I was out the door.
Jeff Pope is sure happy he is here after he escaped CA!
correct, but what’s stopping someone from saying they are Ryan Uecker, and confirm the address and vote before you get to vote. a simple ID could have stopped the situation from happening.
to each there own, and thats why usa kicks ass.
I knew they/them/e/hir/hirs/Xe/xem/Xirs/Ver/vir/Vis/Te/tem/ter/Ey/em/eir lost when they/them/e/hir/hirs/Xe/xem/Xirs/Ver/vir/Vis/Te/tem/ter/Ey/em/eir proposed taxing unrealized gains, and worse, then giving that money to bureaucrats. Government doesn’t need any more of our money. Especially when we don’t even have the money. Unrealized gains are mostly gains from government-created inflation.
https://www.sfgate.com/politics/article/calfornia-counties-flip-to-trump-19897509.php
Another mic drop…No image generated for the preview. Probably a Gurgle block
Image manually inserted…10 California counties flipped!
