Hello all,
My question will show my inexperience…what is this wall that I found in a crawlspace called?
Hello all,
Knee wall.
Did you recommend adding a vapor barrier to the crawl space floor/soil?
I call it a cripple wall if load bearing.
So what is the answer? And AI google is not always your friend, lol ![]()
AI Overview
A cripple wall is a load-bearing, short wood-framed wall between a foundation and the first floor, crucial for supporting the house in older homes on slopes, while a knee wall (or pony wall) is a non-load-bearing short wall often in attics or finished spaces, supporting rafters or dividing rooms. The key difference is function: cripple walls bear significant weight from the structure above, whereas knee walls are for space division or finishing slopes, making them distinct structural elements, though sometimes the terms overlap.
Depends on which AI.
In the context of a home’s crawlspace, a short bearing partition is most commonly called a cripple wall or a pony wall.
While these terms are often used interchangeably by homeowners and even some contractors, they have specific technical meanings depending on where they are located and what they are made of.
This is the most precise technical term used in structural engineering and home inspections.
This is a more general term used in the construction industry.
If the “short wall” is made of concrete or masonry block rather than wood studs, it is called a stem wall.
| Term | Material | Common Location |
| Cripple Wall | Wood Studs | Between the concrete foundation and floor joists. |
| Pony Wall | Wood Studs | Used interchangeably with cripple wall; also used indoors. |
| Stem Wall | Concrete / CMU | The actual perimeter foundation wall of the crawlspace. |
| Knee Wall | Wood Studs | Usually refers to short walls in an attic, supporting rafters. |
Would you like me to help you identify if a specific wall in your crawlspace is load-bearing or explain how to brace one for structural stability?
Or how the question is asked to each….
Cripple walls and knee walls are both short walls in construction, but they serve very different purposes, locations, and structural roles. The terms are sometimes confused or used loosely (along with “pony wall”), but here’s a clear breakdown of the key differences.
Location: Found at the base of a house, between the concrete foundation (or stem wall) and the floor framing of the first story.
Height: Typically 14 inches to about 4 feet (creating a crawl space underneath the house).
Purpose: Primarily structural — it supports the entire weight of the house and transfers loads from the floor system down to the foundation. It elevates the home (e.g., on sloped lots or for access to utilities).
Common in: Older homes (especially pre-1980s in earthquake-prone areas like California), often with crawl spaces and several steps up to the entry level.
Key concerns: In seismic zones, unbraced cripple walls are a major vulnerability — they can rack, shear, or collapse during an earthquake, causing the house to shift off its foundation. Retrofits often involve adding plywood shear walls and bolting to the foundation for reinforcement.
Also called: Sometimes grouped under “pony wall” in broad definitions, but “cripple wall” is the specific term in building codes and structural engineering for this foundation-level wall.
Location: Usually in upper levels, such as attics, sloped ceilings (e.g., in a finished attic or Cape Cod-style home), or sometimes bathrooms/basements.
Height: Typically 2–4 feet (often around knee height when seated, hence the name).
Purpose: Supports sloped roof rafters or creates usable vertical wall space in areas with low-sloping ceilings. It turns unusable attic space into livable area by providing a vertical surface for drywall and insulation. It can be load-bearing (supporting rafters) or non-structural.
Common in: Attic conversions, upstairs rooms with vaulted/sloped ceilings, or as short partition walls.
Key concerns: Structural ones focus on proper load transfer to avoid hinge-like weak points if not tied in correctly, but they’re not typically the primary seismic weak link like cripple walls.
| Aspect | Cripple Wall | Knee Wall |
| Primary Location | Base/foundation level (crawl space) | Upper levels (attic, sloped ceilings) |
| Typical Height | 1–4 feet | 2–4 feet |
| Main Function | Supports entire house to foundation | Supports rafters; creates usable space |
| Structural Role | Always load-bearing | Often load-bearing, but can vary |
| Seismic Issue | High risk if unbraced (common retrofit target) | Lower risk; not a primary concern |
| Common Synonyms | Sometimes called pony wall (broadly) | Sometimes called pony wall or half wall |
In summary, a cripple wall is a foundational element critical to a home’s overall stability (especially in earthquakes), while a knee wall is more about making sloped or low-ceiling spaces functional upstairs. If you’re dealing with home retrofitting, inspections, or renovations, the context (e.g., crawl space vs. attic) usually makes it clear which one is being discussed.
This is another example of regional differences. A term or phrase that is used interchangeably and understood as same/similar although technically incorrect.
In the case of the OP’s question, the actual purpose of the framing would or should dictate what it is called.
See… Google isn’t the issue, it’s the person asking the questions with (or lack of) various keywords and specific phrasing! ![]()
Thanks for all the input guys. Really glad I asked because I was thinking it was an knee wall, but it looks like based on the definitions that are in the chat cripple wall would be more appropriate
Careful, they’re not required (or common) in all locations.
Here in Southern California, we don’t have vapor barriers in crawls.
Most things in California are not required or common in most other locations.
“Terminology varies by region and trade, but the important part isn’t the label—it’s understanding the function of the assembly in the load path and whether it’s performing as intended. A short wall under a floor system needs proper bracing, anchorage, and shear resistance regardless of what we call it. My focus is on identifying defects and evaluating performance, not winning a vocabulary contest.”
For seasoned builders it may be a vocabulary contest but the OPs question was to frame information with correct terminology as a future reference. This is the learning experience correctly done. Good question - thoughtful answers!
Until twenty years ago, we didn’t do vapor barriers here either. Today, vapor barriers are the standard.
Must be due to Climate Change and rising water tables and (oceans)!
Yes, Colorado is at risk also!! ![]()
That’s was I was thinking it was called
You don’t have to know every term for every thing. I don’t know what to call every component of a boiler. Draw an arrow and say “This wall was …”
Google is your friend! It is easy enough to look up the correct nomenclature. You do need to use terminology cautiously. While correct terminology gives a professional touch to your report, it still needs to be written for the client. That may mean leaving out some lesser known terms because they would just cause confusion.
You could however leave a link in the report to a building term definition site.
https://www.autodesk.com/blogs/construction/construction-terms-glossary/
