If a water service pipe is a three quarter inch PEX, is this a defect?
because i just read that the inside diameter will be different in PEX piping.
Used as water service, no.
But used as the TPR valve discharge pipe reduced in size, then yes.
Short answer? Nope!!!
Cheers
You need to be more specific with details…
Regarding standard Supply lines: Overview: Types of PEX and Ways to Connect – Aquor Water Systems.
Other: Pex Tubing - Northern Stoker
Specialty: Large Diameter Cross-Linked PE Pipes #1998
Thank you!
