While doing an 11-month warranty, it appears that there is an issue with the window installation. The windows are manufactured by MI Windows, a brand that I’m not familiar with. I visited their website, but their recommendations on how to install trim around the windows are vague. Since the J-channel does not extend far enough to channel water past each side of the window, is it possible for water to enter the openings on each side of the window? Your help and comments are appreciated.
Mirin does.com/installation
Thank you for the follow up
This email is intended solely for the use of the individual to whom it is
addressed and may contain information that is privileged, confidential or
otherwise exempt from disclosure. If the reader of this email is not the
intended recipient or the employee or agent responsible for delivering the
message to the intended recipient, you are hereby notified that any
dissemination, distribution, or copying of this communication is strictly
prohibited. If you have received this communication in error, please
immediately notify us by replying to the original message at the listed
email address.
This email in whole or in part was dictated to Siri therefore contents may
include misspelled words, dropped words, etc.
Thank You.
miwindows.com/Installation http://miwindows.com/Installation
Report what you said, “It appears that there is an issue with the window installation. The J-channel does not extend far enough to channel water past each side of the window. It is possible that water can enter the openings on each side of the window. Further evaluation is recommended.”
John,
J Channels are not flashing but are cosmetic receivers to hide the cut edges of the vinyl siding. The weird looking trim at the top is Storm Trim and is designed to receive hurricane shutter fasteners for a removable panel type system.
The MI window, and several others have an integral J Channel, the reason for the additional J Channel in this application is due to the Storm Trim which blocks use of hte integral J Channel.
Thank you for the information.
