INachi graphic request thread
(Joshua L. Frederick) #1
CSST bushing/grommet graphic as mentioned here: http://www.nachi.org/forum/f2/corrugated-stainless-steel-tubing-protective-bushing-grommet-103538/
Also, a water softener improperly tapped into sanitary drain one would be great along with one that shows the proper way to do it (with an air gap, trap, etc.)
A house wrap picture would be swell, as well :smiley:
Thanks in advance.
(Daniel G. Desiga) #2
Can this image get an update? It’s hard to read. It can be found on the How to Inspect for Moisture Intrusion course. Thank you
This one too.
http://education.nachi.org/coursemedia/course-57/images/Fig5_flashing.jpg
(Joshua L. Frederick) #3
AC condensate trap graphic also would be nice…
(Roy Lewis, CMI - North Florida Inspector) #4
Would this work for you? Easy enought!
(Michael A. Clark, CMI) #5
The trap needs a clean-out. Those darn things get full of muck and clog, and it’s impossible to get a coat hanger through it! :|.)
(Jeffrey R. Jonas) #6
The one in Roy’s graphic must be restricted… the water level is too low in the trap!
(Nick Gromicko, CMI) #7
CK is on vacation this week, but when he returns, he’ll work on building them.
(Joshua L. Frederick) #8
Appreciate it!
(Joshua L. Frederick) #9
Some other ideas:
-Gas meter clearance graphic
-Don’t vent bath fan to soffit graphic
-Venting bath fan out sidewall (best practice)graphic
Proper crawlspace vapor barrier graphic showing fastened to walls and seam tape
-Proper crawlspace/basement sill insulation (not fiberglass batts)
-Graphic showing why crawlspace/basement sill is a vulnerable area with air transfer
-No tees on horizontal plumbing drain lines graphic
Hundreds more to come :smiley:
(Joshua L. Frederick) #10
  • Proper flex ducting strapping graphic
  • Proper flex ducting installation graphic
  • Plumbing vent to small/frost closure graphic
  • S-trap to P-trap conversion graphic
  • Metal column attachments at beam and floor graphic
(Joshua L. Frederick) #11
CSST bonding graphic
(Joshua L. Frederick) #12
Meter base J-block for vinyl siding or any J-block graphic(s)
Steel post column top plate dishing graphic
Hose bib pitch graphic
(Joshua L. Frederick) #13
Footing drain tile graphic
(Chris Krowiak) #14
I’m on it!
(Joshua L. Frederick) #15
Rubber roof defects/conditions like ponding, ripples, wrinkles, and “alligatoring”
Window hermetic seal failure/causes graphic
Gas fireplace safety damper clamp graphic
Ceiling fan clearance-to-floor graphic
(Joshua L. Frederick) #16
Cool, thank you!
(Joshua L. Frederick) #17
KO flashing with vinyl siding
KO flashing with no mention of what type of siding
(Roy Lewis, CMI - North Florida Inspector) #18
Will these work?
(Joshua L. Frederick) #19
Are these yours? Copyrighted? The whole point of this thread is useable graphics from a paid membership @ Inachi that we can legally use how we fill fit.
I was sued a few years ago for using an image off the net/google.
(Joshua L. Frederick) #20
Safety eyes 6 inch max from garage floor graphic
Safety reverse graphic
Fierwall breaches examples graphic
