How would you emphasize the potential consequences of action or inaction in this situation, in a report?
I’m looking at what seems to be a spray tar repair of a TPO roof, where it transitions to a rusty scupper. The scupper appears older than the TPO roof, and had definitely leaked into the wall.
Inappropriate roof repair. Tar used to repair a prior roof leak is prone to drying out and cracking. Recommend referring to a roofer specializing in TPO roofing, for a repair involving welding the TPO permanently. Recommend adding a second drain a higher level to avoid a “bathtub effect” should this drain become blocked. Without a 2nd drain or overflow, backed up water could reach a depth of nearly 2 feet creating a significant hazard.
Note this report is for the present owner, so there’s no gamesmanship between agents or liability.
Update: I think it’s a rusted through scupper, but with all that flex seal, who can tell now?
You can expand with statements such as “this is considered a temporary repair and will likely fail” or “incompatible patch material” or “substandard repair attempt” and then recommend further evaluation and correction with a qualified roofing contractor familiar with TPO repairs consistent with industry or manufacturer standards.
Prescribing cures is a slippery slope. I personally would stay in my lane and identify the defect.
