I would just install a 200 amp service. The difference in material costs is minimal between a 200 amp and a 150 amp and the amount of labor is the same.
This is good advice
I don’t understand the power lines capacity. From the utility. How many amps are in those utility conductors???
It doesn’t really matter. If they need to be upgraded they will upgrade them.
And thanks guys for freely passing on this information.
Just a regular electric car. A grocery grabber.
We stopped using the chart in 2014.
150 AMP breaker X 83% = 124.5 AMPS. #1 is 130 AMPS, so #1 is OK.
Thank you sir.
What would the calculation be for a 200 amp service???
Overhead/underground? Call them first. Explain what you are doing. While the NEC applies to you they are the ones supplying the power. They may have certain rules in your area
I will do just that.
Overhead service to a gooseneck 10 feet clearance
This is the NESC
Are you in Michigan Robert
Read his sig
I don’t understand
You mean the non member
New Jersey
How did you determine that
Read his “signature”
I have a lot to learn. And when I do, I will be just as helpful and patient with the next new guys as you all have been with me. Thanks
