Originally Posted By: bsilowash
, by Norman Becker, says that “Once the panel cover has been removed, the actual inlet service capacity can be determined. It depends on the size of the inlet service wire only, not on the rated capacity of the panel box or the size of the fuse or circuit breaker used for the master disconnect, if there is on.”
That's great, but assuming that you want to know if the rated capacity of the panel or the size of the master disconnect was matched to the size of the inlet service wire, how can you tell?
My inlet service wires are not labelled to indicate size, and I can't measure the diameters. So how do you folks determine the inlet capacity?
