I am doing a 4 point on a ground floor condo in Florida. Dumb question. Do I have to inspect the roof over the 2nd floor?
Anyone have an answer. This is my first one like this.
Be prepared…
- HOA won’t allow access…
- Unless you have an extra tall ladder, and are comfortable with heights, you won’t have access…
- Drone… HOA won’t allow them, so you won’t have access…
- Other than above, you likely won’t have “interior” access.
With all that being said, I always attempt access regardless of any limitations.
Remember, All Condo owners will share in the costs of maintenance and replacement of the Roof and Exterior components, thus it is in their rights to allow for access to inspect.
But, I’m in Minnesota, and we do things differently here, especially when it comes to being bullied by HOA Karens!!
Note: Your Inspection Agreement should have a (Legal) Disclaimer explaining the inherent Limitations with Condo inspections and your (common) inability to inspect certain areas as defined by the HOA and/or generally inaccessible areas.
I state on the 4-point form for condos, no matter what the height: The roof is the responsibility of the HOA. Have not had an issue with insurance companies.
All good points except I’ve never had an issue with the hoa stopping drone use.
Of course I never ask. FAA owns the sky. If they say I can fly, I fly.
I’m usually done before anyone notices anyway.
If it’s a condo then which floor it’s on doesn’t matter for the 4-point. You can leave it blank (explain it briefly in the Additional Comments Section).
