Inspecting a Tiny Home at the Manufacturer Before Shipment — Advice Needed
Hey everyone,
I received an inquiry from a client who recently purchased a tiny home that’s being built by a manufacturer in another state(built in my state, shipped to them.) They want an inspection done at the factory before the unit is shipped to their final destination.
I haven’t done an inspection on a tiny home before and especially not something being delivered so I wanted to ask:
  • Has anyone here performed an inspection on a tiny home at the manufacturer’s facility before shipment?
  • Is this something inspectors typically take on, or is it outside the normal scope of a home inspection?
  • What are the key things to look for during this type of inspection (structure, systems, fit and finish, etc.)?
  • Are there any added liability concerns since the home will be transported after the inspection?
  • Finally, how would you approach pricing for something like this—would you treat it similar to a standard home inspection or adjust based on the scope/travel/time?
Any insights or experiences would be appreciated!
Morning, Abe. Hope to find you well.
I have never been asked to inspect a manufactured home at the manufacturing site before delivery. A pre-delivery inspection or (PDI).
I would take on the inspection as well as advise the client to have the manufactured home inspected after the manufactured home was installed on site, or at least an 11th month warranty inspection.
I take it the PDI would involve the inspection being conducted by yourself and a builder representative, to inspect the home’s interior and exterior and any specialized items the client ordered.
What to look for? Take the course. How to Inspect Manufactured and Mobile Homes
Added transportation damage. One would think so. How many miles to the location where the home will finally come to rest?
Sell yourself. Recommend an 11th month warranty inspection.
Myself, pricing? Adjusted based on the scope/travel/time.
Likely going to get some great ideas from members that have done this type of inspection before.
Good luck.
Hope my part helps.
Robert
Step one, get permission from the manufacturer to enter and inspect their property. Until this is obtained, everything else is moot.
After that Florida Building Code Residential Appendix Q outline Tiny House requirements. This may help you with some details.
https://codes.iccsafe.org/content/FLRC2023P1/appendix-q-tiny-houses#FLRC2023P1_AppxQ_SecAQ104.1.3
For instance:
AQ104.1.3 Height effect on loft area.
Portions of a loft with a sloped ceiling measuring less than 3 feet (914 mm) from the finished floor to the finished ceiling shall not be considered as contributing to the minimum required area for the loft. See Figure AQ104.1.3.
Exception: Under gable roofs with a minimum slope of 6 units vertical in 12 units horizontal (50-percent slope), portions of a loft with a sloped ceiling measuring less than 16 inches (406 mm) from the finished floor to the finished ceiling shall not be considered as contributing to the minimum required area for the loft. See Figure AQ104.1.3.
^^^ That, plus the client is the one that needs to address that access issue, which I doubt would be granted anyway.
It makes more sense to inspect the finished and installed product when completed on-site, not in the warehouse before it’s delivered, manhandled, and tweaked once placed wherever it’s going to land.
Among the other issues with this that concern would be the most important (bold above). If you truly document the bejeezus out of the home before it is moved then your liability is significantly decreased. However without utilities connected you have no idea what the full condition of those components are. If damage occurs during transport you may never know when the failure cause occurred. That is always a potential liability.
I suspect this buyer wants the condition documented before hand to hold the supplier accountable for transport damage. Go back to the concern I mentioned and that is where your liability might increase. Not to mention getting involved in an interstate type lawsuit, if it occurred against the supplier, can cost you more than any inspection can possibly be worth.
Remember in a lawsuit the plaintiff will reach for the deepest and easiest pockets and quite frankly your pockets are easier to get at.
Unless the buyer failed to ensure their purchase contract covered damages then this type inspection makes no sense. If the buyer did not properly affect a contract for sale and delivery it makes no sense for you. Personally I would pass on any type inspection until the house is on the final destination site.
I suspect this is the primary reason the client wants the inspection.
Did you have a full conversation with the potential client to determine a Scope of Inspection?
Among the other things listed above, I can’t imagine they hook everything up at the factory. So none of the mechanicals will be functional. It won’t be on a foundation so a door that opens while it’s at the factory, may not open if they don’t level the thing right.
If I were going to do anything it would simply be to take a lot of pictures and make sure all the doors and windows open and close. A 15 minute inspection tops.
A pre-shipping inspection. Scope is limited to visual surfaces and function of doors and windows. Clear it with the MFG too, in writing.
You can maybe talk to the mfg and maybe they hire you on the regular. They can spout “All our homes are inspected by an independent 3rd party before shipping!”.
Since none of that is going to happen, good luck.
The greatest concern to me is what happens in shipping.
What is the mfg warranty? Everything should be shown to be working when it arrives, not when it is on the assembly line.
I would not waste my time on this.
1st it is not a home inspection. It is not Real Property, it’s Personal Property like an RV.
2nd will your insurance cover this activity. Willing to take on any complaint on your own?
Someone asking for this is a concern to me also. Do they have an appliance contractor inspect appliances before shipping from Home Depot? :thinking:
