I have chosen a photo regarding the proper handrail height for a residential stairwell. It shows the proper distance between 34 and 38 inches. It is also important to note that the railing should support at least 200 pounds of force in every direction.
The photo shows three stair risers with two notable defects. For one, the risers are 4 inches on the top and bottom riser, the middle is 7 inches. This is over the allowed 3/8 inch of variance, and does not feel consistent.
I read the article about stair requirements for egress. The stairs should be a minimum of 36 inches wide, with standard riser and tread of 7 inches and 10 inches. The railing should feel safe, and not allow a 4 inch ball to protrude through any portion.
This is an exit door. If there is a ramp beyond the door, the ramp must not be more narrow than the doorway itself. In inspecting ramps there are 3 main points to check for ramp inspection: slope, landings and handrails.
There are a variety of tools every homeowner should have. They should consider a combination wrench set, tape measure, hacksaw, flashlight, torpedo level, claw hammer, goggles, caulking gun, screw driver, wire cutters, safety mask and duct tape. These are essential to correcting minor issues within the home, if only a rudimentary knowledge of the subject is known.
Upon inspection of stairwell found broken handrail, this could cause someone to fall and doesn’t comply with recommended standards, I recommend repair of handrail as well as verifying wall has not been damaged where the handrail connected to the wall.
Upon reading the article, Shrinkage in Concrete, I found it interesting that what causes surface cracks in concrete is the water that is mixed with sand or concrete evaporates and can cause surface cracks which is ecpected and acceptable as these cracks are just in the top layer of the concrete.
Emergency escape and rescue openings:
An exterior windows, egress door or similar component that can serve as a means of escape and access for rescue in case of an emergency.
The minimum net clear opening requirement is 5.7 square feet.
Adobe inspection is a natural building material made from clay and sand mixed with water and an organic binder, such as sticks, straw or dung. They are commonly built in low-income communities that lack the resources to construct more complex or conventional designs whose components are more costly.
I selected an egress door for my essay . The egress door has to be at least 36 inches wide and 6 feet 8 inches tall. The door must open over a landing which should be no more than 7 3/4 inches lower than the top of the threshold . The door also has to be hinged to swing open and can not be a slider. The door must not open into a garage to be considered an egress door.
Stairways are by far the most dangerous places in the house. There are more people that die or are injured in falls on stairways . Some of the most important things to remember about stairways is that there should be no more than 3/8 of an inch difference in any of the riser heights, balusters should not be farther than 4 inches apart, there should be at least one handrail on more than 4 risers, and that the treads should not be loose or slippery . you should make sure that there is proper lighting that keeps the whole stairway illuminated .
While in general, the stairs, doors, and landings are built into the home and expensive to change, it is worth noting in your report to inform the buyers of any safety issues that may be present. It will then be up to the buyer to correct if they so choose.
The main egress into and out of the house requires certain standards be achieved to be both safe and ‘in code’. This ‘front door’ threshold is 4 inches above the front porch. The front porch is 7ft x 7ft, greatly exceeding the width of the door.
A deck needs to be examined as a part of a complete home inspection. Decks offer unique areas that can cause significant harm to those either on or under it. From load abilities, how it’s connected to the home, and the spacing between vertical rails; decks need to be completely assessed.
This is the point of egress in this residence. The door is 36"x80". A defect for the egress door is that it has a double sided dead bolt, that you have to have the key to unlock it in a time of emergency.
When inspecting stair ways you should check the landings, stair treads, handrails, and spindle spacing. The stairway should be at least 36" wide. The handrail should be 34"-38". The spindle spacing should be less than 4". The landings should be at least 36".
This photo shows the vertical rails on the stairs to be under 4 inches and would not allow a sphere with a diameter of 4 inches to pass through. The risers also measured adequate height and spacing to now allow a sphere of four inches to also not pass through. The rails were also of adequate height, had a grip, and were continuous.
The article I read discussed the advantages of using solar energy. While it does have some flaws, the upside greatly outweighs by a large margin. While renewable resources can become scarce, the amount of solar energy that can be harnessed is more than humans could ever need and use. It is also low emission, creates green jobs, and it is extremely reliable.
Window well emergency egress must be a minimum of 5.7sqft or 20"tall x 24" width opening. The outside widow landing well must be a minimum of 36"x 36". If the height of the window well exceeds 44" a ladder must be installed with rungs not exceeding 18" in height and a minimum of 12" in width.
