**Q: **The maximum amount of fuel oil stored above the ground or stored inside a house is _____ gallons.
250 gallons
660 gallons
1,200 gallons
**What’s your guess?
250 gallons
660 gallons
1,200 gallons
Zero…
Unless you live at a Jiffy Lube of course.
660…
You can have two 330 gal. tanks side by each in a building.
Depending on your location and jurisdiction and Heating , and fuel oil codes, you may be required to provide a containment for at least 110% of the oil contained. That usually takes affect at an amount of 500 gallons.
660 gallons
660 Gallons
It’s 660 gals, no guessing here…
660 gallons
660 gallons
660 gal
