What could happen if a new home is not inspected to determine if the building is structured with allowable spans and building materials? After the building structure is covered with drywall, no inspector will be able to verify proper building practice of spans and materials; however, with time, floors and ceilings may sag, walls may shift or bow out, windows may be difficult to open, doors may loose plumb, etc. Looking at the roofing structure in the attic could give us a hint about the kind of work that that particular builder did around the house, however a pre-drywall inspection is always recommended.
Does the AHJ not perform plan review & pre-drywall inspections in your area?
You ask a question, answer it, then make a bunch of statements……… Is there a point here?
Morning, Mario. Hope to find you well.
To answer that question, it becomes a limitation. Although a thermal camera may allow a glimpse into certain structural assemblies when a delta T is present.
As for your attic structure comment. It to is a limitation, in most cases, eg: a: if insulation or any other component covers portions of the assembly. b: when the attic is not crawled from end to end.
To my knowledge, I know of no jurisdictions where Home Purchasers are forced to do pre-drywall phase inspections. A recommendation is just that. A a suggestion or proposal.
Is this one of those student question-type (or “I just started this course”) posts??
Looks like a post that should have been placed in the Student Discussion: Pre-Drywall Inspection Course
You’re right, sorry, didn’t notice
It is important to verify spans and materials during a pre-drywall inspection to verify that framing materials, and fasteners meet current building standards. If this is checked before it is concealed any issues can be dealt with prior to the home having possible structural failure and costly repairs. It provides buyers confidence that their major investment is constructed correctly.
Inspecting for allowable spans and materials in a residential home is a critical part of evaluating its structural integrity and long-term performance. During an inspection components such as joist, rafters, and beams can cover without excessive defection or failure are compared against established standards. Inspectors also look at the material used to assess the quality and condition. Not inspecting a newly constructed home could lead to premature failure, uneven floors, and roof deformation, or compromised structural stability.
Inspecting for allowable spans and materials in a residential structure is a critical part of ensuring that the framing system is built according to code and performs as intended. During this inspection, the inspector verifies that floor joists, beams, girders, and ceiling members are of the correct species, grade, and size, and that they comply with the allowable span requirements outlined in the IRC span tables such as R502.3 and R802.5. It is also important to confirm that the installed materials match the approved construction drawings and are properly grade-stamped.
If inspections are not performed or are inadequate, structural members may be undersized or improperly selected for their intended loads. This can result in excessive deflection, bouncing floors, sagging beams, or long-term structural distress that may not become visible until after finishes are installed. In more serious cases, improper spans or materials can compromise the structural integrity of the home. Proper inspection at the framing stage helps ensure code compliance, safety, and long-term durability of the structure.
