Insulated foundations & slabs
I’m in the education portion 2.4.3-.5 area “slab on grade insulation & finishes”. How recent are these standards for insulating under slabs and outside of basements with foam board? I’m in northern Ohio and I think most of the builds here predate even the existence of these foam board materials. Are these standards for insulation layers on the slab adhered to much in the field outside of high spec new builds? Since there would be little evidence of where the insulation and vapor barrier layers are, is it a topic that’s just shrugged at and is just “best practice” knowledge?
Well, it’s more than “best practice” but less than a code requirement which only addresses frost proofing footers.
Around here in Colorado, it is a standard practice and has been for about twenty years to insulate foundation walls. You bring up an interesting question that I don’t know the answer. Is it market forces that have our foundations insulated today, or some local municipalities requiring it as part of the overall energy conservation movement that is so popular here?
For us in Minnesota and other COLD regions, Foundations and increases to building exterior wall insulation was mandated by the Department of Energy codes around the “turn-of-the-century”! (Makes ya feel old, doesn’t it)?!
Talking with some ‘High-end’ Builders, this required some (larger home) walls to be thicker than 2x6 construction, which equated to the addition of exterior hardboard insulation.
Many towns in MN now require that additional insulation be added to the exterior when repairing large sections of, and/or updating the exterior siding.
