Greetings legends of home inspections, this is an older lake home…there was a low clearance ceiling in the basement and insulation is stuffed between joists both ways, but mostly barrier down (toward the basement floor) of course the vapor barrier should ‘always face the living area’ but commonly referring to walls and upper ceilings. So I suppose the former owners wanted to be able to heat the home and not lose heat into the basement and adjoining crawspaces. What is one to do? you cant vapor barrier both sides and the lower level had the look of a place which had substantial dampness issues and a dehumidifier chugging away persistantly. There was no cross ventilation. In the pic you can see where moisture evidently gathered til it popped a hole and fostered a mold garden. Should I have recommended removing all insulation and ignore the lost BTUs? Poly below only and get some ventilation installed? Research in this area results in myriad opinions of the ‘right way’ and is always dependant on specific details. What is opinion of the interNACHI elite?
all responses appreciated
mike in MN
** **Less ventilation might allow less moisture to enter, ,a larger dehumidifier with a hose to the drain. ,More dirt around the out side down spouts away from the home . Punch many holes the insulation paper so it can breathe .seal the walls/Rafters so less air/moisture enters.
Thanks Roy…I am getting that you do not recommend ventilation. The gutter system was pretty adequate. Punching holes in the vapor barrier…interesting idea. what about using unfaced batts? So any moisture driven out of the living quarters can simply pass through…of course moisture from below might also be driven upward. I guess it would depend on which area on which side of the floor is pushing hardest for whatever reason. I have limited understanding of the pressure scene. I would guess the upper level is more likely to be affected pressure wise (open windows, exhaust fans etc)
thanks for all time
mike in MN
New computer and having trouble will look for a file and send it to you lots of info .
Try these still looking
Added below
http://www.buildingscience.com/documents/reports/rr-0401-conditioned-crawlspace-construction-performance-and-codes/view?searchterm=Crawl spaces
PDF]
BSC Information Sheet 512 Crawlspace Insulation - Building …
www.buildingscience.com/.../information-sheets/gm-building-americ…
WWW.basementsystems.ca
I have little time for these tpye of contractors … Roy
Yep we can do it we fix it from the inside .
Crawl Space Repair with the CleanSpace Encapsulation System
Lire en français
We’ve Been Creating Drier, Healthier, More Energy Efficient Crawl Spaces Since 1987!
http://www.basementsystems.ca/images/crawl-space/crawl-space-system-thm.jpg
Our Warranted Products
At Basement Systems, we’ve developed a complete line of more than 30 award-winning, patented crawl space products. Each of which has been customized to meet specific needs you may have in mind for your crawl space.
More on our Award-Winning Products
If you’re looking to repair or upgrade your crawl space, we’re the expects you’ve been looking for!
We have the experience, warranted services, and award-winning products you need to transform your crawl space into a more valuable space.
As members of the world’s largest crawl space contractor network, the experts at Basement Systems have successfully completed work in tens of thousands of crawl spaces. We specialize in the areas of encapsulation, moisture control, crawl space waterproofing, structural repairs, and insulation.
We are Crawl Space Specialists!
Basement Systems provides each CleanSpace dealer with ongoing training at our headquarters – which we supply to thousands of experts within our network each year!
Our complete CleanSpace system includes a written warranty – one that’s measured in decades, not years! This warranty is fully transferable to the next homeowner – a big advantage when selling your home!
With more than 300 dealers throughout the network, we serve nearly every local area in Ontario, Quebec, Alberta, British Columbia, Manitoba, Saskatchewan, and throughout Canada.
Looks kind of intrigueing …what dont you like about it Roy?
Water is the strongest solvent in the world .
If you have any doubts look at the grand canyon it happened one drop at a time
I have seen in this system the blocks slowly getting dissolved .
You cannot water proof a boat from the inside and the same goes for a house.
Stop the water from entering instead of trying to control the water from coming into the home then pumping it back outside to come into the home again .
well spoken Sir Roy of Brighton…and as always, from thy fingertips, food for serious thought methinks
mike of downunder
