Proper insulation and technique for insulating a basement?
11 month home with a full basement with 2x10-16 O.C. No heat source other than radiation off the boiler. Is it OK to install a paper faced insulation with the paper facing UP toward the kitchen BUT have a 2"-3" gap between the subfloor and the paper? or should it be tight to the floor, or should this insulation be unfaced plain and simple?
Thanks,
