InterNACHI releases new wind mit and 1802 form free, online course
As of April 1, 2026 Florida has updated its requirements for performing Wind Mitigation Inspections as well as the 1802 form.
InterNACHI has released it’s new training course, 2026 Wind Mitigation and the 1802 Wind Mitigation Form course, so Florida inspectors can be educated on the new requirements.
This course is being released as an informational course only at this stage due to the timing of the new requirements; the course is pending DBPR approval for continuing education, but at this time is not approved for CE.
InterNACHI’s previous wind mit course, How to Perform Wind Mitigations, is still approved for 16 hours of continuing education and should be used for CE until the 2026 course is approved by the DBPR.
That’s good news there is lots of demand for this.
Hopefully all Florida Inspectors are aware of the the new (since 2020 FBC) requirements for roof sheathing and roof sheathing attachments…
The Exposure C is a big requirement. Did you check it vs the Existing Building code?
R301.2.1.4.3 Exposure categories. An exposure
category shall be determined in accordance with the
following:
Exposure B. For buildings with a mean roof
height of less than or equal to 30 feet (9144 mm),
Exposure B shall apply where the ground surface
roughness, as defined by Surface Roughness B,
prevails in the upwind direction for a distance of at
least 1,500 feet (457 m). For buildings with a
mean roof height greater than 30 feet (9144 mm),
Exposure B shall apply where Surface Roughness
B prevails in the upwind direction for a distance of
at least 2,600 feet (792 m) or 20 times the height of
the building, whichever is greater.
Exposure C. Exposure C shall apply for all cases
where Exposures B or D do not apply.
Exposure D. Exposure D shall apply where the
ground surface roughness, as defined by Surface
Roughness D, prevails in the upwind direction for
a distance of at least 5,000 feet (1524 m) or 20
times the height of the building, whichever is
greater. Exposure D shall also apply where the
ground surface roughness immediately upwind of
the site is B or C, and the site is within a distance
of 600 feet (183 m) or 20 times the building
height, whichever is greater, from an Exposure D
condition as defined in the previous sentence.
It is. It is also a large area.
This is from FBC 2020
R301.2.1.4.2 Surface roughness categories.
A ground surface roughness within each 45-degree (0.79 rad) sector shall be determined for a distance upwind of the site as defined in Section R301.2.1.4.3 from the categories defined below, for the purpose of assigning an exposure category as defined in Section R301.2.1.4.3.
  • Surface Roughness B.Urban and suburban areas, wooded areas or other terrain with numerous closely spaced obstructions having the size of single-family dwellings or larger.
  • Surface Roughness C.Open terrain with scattered obstructions having heights generally less than 30 feet (9144 mm). This category includes flat open country and grasslands. This Surface Roughness shall also apply to any building located within Surface Roughness B-type terrain where the building is within 100 feet (30.5 m) horizontally in any direction of open areas of Surface Roughness C- or D-type terrain that extends more than 600 feet (182.9 m) and width greater than 150 feet (45.7 m) in the upwind direction.
  • Surface Roughness D.Flat, unobstructed areas and water surfaces. This category includes smooth mud flats, salt flats and unbroken ice.
Check what?
