Is this a problem?
Originally Posted By: jremas
I found this small hole on a back enclosed porch. Something is telling me there is a problem with the roof.
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
570-362-1598
Well, I thought for a couple of minutes about some smart a$% comment but just couldn’t come up with an adequate one.
However, don't count on the roof until you eliminate other moisture sources such as pluming pipes or condensate drains in the attic.
Erby Crofutt
B4U Close Home Inspections
Georgetown, KY
www.b4uclose.net
Originally Posted By: Sean LaSalle
Jeff,
It actually looks like a garbage compactor back fired? Why would they have put one up there anyway? ![icon_surprised.gif](upload://57CELbNgOav4I8DdysEp4jSUiyx.gif)
Originally Posted By: Aaron Rosenbaum
Erby Crofutt wrote:
However, don't count on the roof until you eliminate other moisture sources such as pluming pipes or condensate drains in the attic.....
Very true....
If there is nothing above it... then its a roofing issue (of course), but if there is another floor above it.... then its very possible a pipe could be leaking or if there is a toilet above, it might need to be reset.... you'd be surprised how such a small leak can cause a lot of damage....
