Is this okay?
Originally Posted By: sgilligan
Not sure if picture posted okay, but is this acceptable? The bottom of the vinyl siding is under mulch.
Okay someone help me post, I’m trying jpeg.
Your pictures were probably too large to download properly. Try resizing them down a bit.
There is also a "Sticky" topic under "Misc Discussions" for testing out posts, uploading pics, etc ...
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: tgardner
It’s never a good thiong to have the siding buried under 8" of termite munch’in mulch. Try " The inspector noted that portions of the siding are too close to (buried under) ground level, making them subject to decay or insect infestation. All siding should be a minimum of eight inches above ground level."
tg
Originally Posted By: dvalley
Shawn,
When I see situations such as this, I always recommend an invasive inspection of this area (if you can't get to the sill area). When I see dirt up against the house, 75% of the time I find termite activity or rotted sills.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: rcloyd
It is absoulutley amazing how much combustible dry twigs and wood chips (mulch) people will pile up against the thing they are sleeping in!
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
