Is this typical for gas logs
Originally Posted By: jlybolt
http://www.nachi.org/bbsystem/usrimages/gas logs.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/1/gas logs.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/1/gas log.JPG ]
Originally Posted By: jhagarty
James:
You would need to check the manufacturing specs for the flex line to determine acceptability in tghis application. The line appears to be excessively flexed.
Is there an isolation valve at the unit?
The clamp in the one photo appears to be fior the damper to prevent closure as this appears to be a vented Gas Log set.
The material in the bottom is Vermiculite and Rock Wool. It is a necessary component with some manufacturers of gas burners.
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Joseph, thanks…
There was a cut off valve near the unit with t-handle.
what do you think about the flex gas line running along the bottom of the log unit. Isnt it to close?
Originally Posted By: jkormos
The Vermiculite and Rock Wool also add to the ambiance of the unit, adding some “glow”. I would also check the manufactures specs.
Originally Posted By: dandersen
I think it stinks, but this is common.
That clamp in the first picture belongs on the damper so it can't be fully closed.
thank you everyone for the help. Its greatly appreciated. icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
