Utility basement-moisture/dampness
Maintenance required
There are visible moisture stains in the rim joists and / or subfloor on the mid east side and south area of the west side .A moisture meter reading was takat the stained areas and identified to be active at the time of the inspection. The moisture on the east side appears to be from the stoop are and the West side moisture appears to be from the roof vent boot and or leaks in the waste vent lane .The inspector recommends contacting a qualified contractor tto the further evaluate and make recommendations for proper repair.
Alrighty then.
