dberry6
(David Berry, Certified Professional Inspector)
I was conducting an inspection and found what appeared to be salt on the post.
I was in full Tyvek with a respirator that had started to fog up, so I could not see well. I am new but I have never seen this amount to salt built up on wood posts like this.
Is this normal or is it due to excessive moisture, or something else?
Thank you for your help.
This is in Washington State on the west side; it is about 30 miles inland.
From my point of view here it doesn’t look like salt.
Was it on all the posts and only at the base?
dberry6
4
I scraped it with a bit of wire that I found in the crawlspace. It was not soft like something organic, it was not a crunchy as I thought it might be. But it did sparkle a little under my flashlight and the camera flash.
dberry6
5
It was only at the base. The posts run to the footing is just below the black vapor barrier.
So, just a theory. Sap or water draining down from the lumber? I have seen some very very wet treated lumber before. And the chemicals used may react to something such as the mat underneath.
Also, a good place to perform a pick test to determine if deterioration is present.
It’s some form of wood decaying fungi.
What are the “black squares” for?
Is that a cement or soil base? That wood is like a wick sucking up H20 or coming from above?
Poor adhesion/failed design of mastic-strip or hydrostatic waterstops?
If my theory is on target, the structure is not very old… ? >>
