Ladder stability & gutter damage
Hi,
Has anyone used one of these? Or a similar product?
Is this a good idea?
Thanks
The device in the first picture seems like it would be difficult to install and not work on all applications. I’ve used the device in the section picture, they work well.
The one on the left you have to put up before the ladder. How can you on a two storey?? The arms on the right are great for stabilty.
Yeah I have one of these but I have not tried it yet on an actual roof/gutters yet.
What you do is use one end of your painters pole and hook it up to this mount (that area is hard to see in the picture) and then extend it all the way and drop it inside the gutters.
I already have a painters pole for my pole camera which I can use for this setup. But I am not sure how efficient this whole process is.
I personally do not like anything that might create a tripping hazard. Watch this video and see what should be done on any inspection of a roof. This is the most secure and trusted way by all Professional Home Inspectors.
Devices that attach a ladder away from the home are generally designed to work on the exterior painting and installing windows ect. They also do not provide a secured ladder only a stable ladder.
What can also be noted is both pictures do not follow the 4 in 1 rule.
(Video) If that was my roof, I’d be pissed…no damage to the roof, lol.
Also, the cleat is a real bad idea if not nailed into a truss…false sense of security that will work loose.
Oh sorry I don’t agree with that part of the Video. Only the first part of securing the ladder. If you feel the cleat will pull out I think you might be a bit paranoid. However I also check the location for securing before attempting to get on the roof.
Trickiest ones are the plastic gutters and yet I have no trouble myself with them yet.
Cleat will not pull out under normal use, but is the most stupid suggestion I have seen.
I can just see the client now. :slight_smile:
I have seen his guy’s other videos as well. He is very big on safety - which is great.
I do tie my ladder to the gutters but what I mentioned in my original post was about something that we can use to give our ladder more stability before we actually reach the top and get the chance to tie the ladder. i-e ladder stability from the time you setup the ladder till the moment you reach the top.
You might be right, in the second picture it seems like if the ladder was setup at the correct angle, it might end up touching the gutters anyways - which defeats the purpose.
I guess, I have to try it to see if it works.
Both these devices look like good ideas, easier to use on some roofs than others since some have no gutters, or old, rusty, fragile gutters. On an old, steep, slate roof with no gutters and a big overhang? Well, that’s always going to be tricky and you just have to take it house by house and do your best to do your job and be safe.
Still waiting for a video on the ice axe and crampon method of ascending a shingle roof.
http://www.nachi.org/forum/data:image/jpeg;base64,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
http://www.nachi.org/forum/data:image/jpeg;base64,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
