Lateral Grounding Question
if a home has a lateral electric service, does it need a grounding rod
ALL services require a grounding electrode. Most require more than one.
The quick answer is yes.
the longer answer is that it may use something other than a rod, such as an Ufer ground encased in the slab.
Regards
Gerry
