Lead Paint Inspections - ky
My state of KY is now requiring lead based paint inspections. I have several questions that haven’t been answered by our “agency” in charge. I would like to chat with someone who is testing in their jurisdiction (not necessarily KY). Thanks in advance.
Is it really this simple to test for lead paint? :point_down:t4:
“Testing for lead is simple. Spray solution on the paint and wait to see if the color shows traces of lead. If results are positive, homeowners may be eligible for up to $17,000 in assistance to remove lead hazards…”
From what I have been told, this is only for rental properties and for homes that are being purchased under the Kentucky Housing Corporation (KHC) program. This is not for all homes in KY. This site should help you, it has all of the information you should need for lead testing in KY.
https://www.chfs.ky.gov/agencies/dph/dphps/psb/Pages/lead.aspx
It is assumed that if you have a home built before 1978 that lead based paint exists in the home. You can test for it but you would have to test every surface in the home by taking an utility knife and making a small cut at an angle (to get all layers of paint) and then testing with an EPA approved test “sponge”. So for practical purposes it’s not possible to “clear” a suspect house. Instead they require workmen who work on a pre 1978 house to be EPA certified under the RRP rule. The workmen will test the area they’re going to repair and if it has lead paint then special precautions and cleaning is required.
I didnt watch the video, but I am assuming it is not that easy…
If this is just a solution you spray on the surface, it is only going to test the top layer, which will not have lead paint unless it hasnt been painted for at least 48 years
