Leaking Conduit?
Originally Posted By: rpierson
Hi All!
Came across this yesterday.
The spa was leaking into the control panel, and into a conduit that ran underground to the 60 AMP 240 Volt disconnect about 10 feet away.
The owner claims it works fine! It just leaks.
I showed him the problem and advised I would NOT test the spa and requested he keep all power to the spa disconnected until a licensed electrician approves installation.
Originally Posted By: tallen
I am curious. Does anyone check for leaks in a pool or spa and if so what method do you use?.
I don't mean the pool equipment. I mean the pool itself.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Sure do Todd,
I tell my clients if they want me to check to see if there is a leak I will.Or they may and probably should do it themselves.
I use the bucket method.
What the hell are you talking about ?? Bucket method. That’s nuts! icon_rolleyes.gif
Originally Posted By: rray
I don't test for leaks as part of my pool inspection.
Home inspections. . . .
One home at a time.
Thank God,
I thought I was the only one allowed to post here icon_lol.gif icon_lol.gif icon_lol.gif
LOL!
Go get'em Todd!
I see that no one does check for leaks.(apparently)
So what do you do? Look in the pool for cracks and call it a possible leak?
If said crack is found do you defer it for a dye test?
I look for cracks, call them cracks, and recommend further evaluation, which may or may not include a dye test, bucket test, or whatever.
One home at a time.
Of course, we also have vinyl pools and pebbletec pools. Those make it difficult to see cracks. What then?
One home at a time.
I do the same thing a crack is a crack further evaluation needed.
If it is pebble tech you would be lucky to find a crack if you checked out the whole pool with a mask.
